Front airmatic strut replacement
I purchased 2 Arnott struts (remanufactured) struts for the front on Black Friday, but turns out they are actually out of stock (they don't have any cores) and don't know when they will get them. I preferred to go remanufactured due to the cheaper cost (I will upgrade to new GLE in 1 or 2 years at most), but having said that I don't want to go with poor quality stuff which may break down or cause the ride to back to being bad.
1. Since I can't get Arnott remanufactured, what is another remanufactured brand folks have used and recommend? I have seen Suncore and RMT online, but don't know anything about the quality or durability. Just FYI, I did call Arnott and they said if I send them my struts, they will rebuild them, but it is 2 or 3 weeks turnaround, which maybe difficult for me to manage without the car working so I am looking for a "comparable" alternative.
2. On the rears, is it enough to just replace the bags if the car is bouncy or would you recommend the struts. I was going to replace the bags only and then if the car was still bouncy in the rear, I would do the struts. But maybe someone already has experience on this.
3. Anything else that you would recommend to get the ride back to its original state?
TIA
TIA
Thry stock oe bilstein shocks and Arnott
https://www.fcpeuro.com/Mercedes~Ben...14&m=20&e=4260
Arnott and RMT also have none in stock, only option is for me to remove my struts and send it in for rebuild (car would be out of commission for 2 to 3 weeks depending on which vendor I select). Arnott is around $1,020 to rebuild both, but RMT is about $775 and neither could tell me why their rebuild is better than the other. I have not checked with Suncore and others. That is why I posted to see if there were other remanufactured brands people recommend. The only available aftermarket struts that I can find are Chinese made which I think I want to avoid.
Maybe I'm missing something?
Apurva
Apurva
I checked 5 mercedes dealer parts websites and every single one says the replacement front strut is discontinued for your vehicle. Thats extremely weird.
I would call the Mercedes parts counter at your local dealer and try to figure out what is wrong. Also try calling fcp euro Tom morning. They are usually a great help.
I have the feeling mercedes dropped the ball on this part as well and underestimated the fail rate of the air strut.
I replaced all 4 corners on my 2010 🙄
Did you use Arnott on your replacement? Are you happy with the performance?
I would recommend Bilstein which is oe but I checked their site and they list nothing for the front. Only rear.
Youre only at 4 years...mine started going at 6....the quality of the part must have gotten from bad to worse.
Schedule an appointment at the dealer.
Drop it off. Get into a loaner.
Negotiate labor and parts for 1k or less a corner.
Get mbusa customer care involved. Throw a tantrum and fight them to make sure they take responsibility for fixing this on their cost.
You ride around in a loaner till youre happy with the results.
And please strongly consider doing it this route. Play hard. Be firm and tell them it is their responsibility. This should not happen and they should take care of you if you are considering a gle in the future.
I got a 5$k voucher last time for new purchase but I had an extended warranty fix everything. Make sure to get both.
I replaced all 4 with oe mercedes remanufactured parts at the dealer. They also replaced my compressor and rear levelling rods. I'm happy.....😬 my extended warranty paid for everything though so ymmv
I am finding OE at some of the mb dealer sites, but not all (don't know why).
https://parts.mbfm.com/p/Mercedes-Be...663204966.html
It is about $815 which is over double of what remanufacturing mine at RMT will cost. So that is why I'm seriously considering figuring out how to make due with my other vehicles for 2 weeks while they rebuild mine.
If you are considering remanufactured. Stick to arnott or oe mercedes.
Try the mbusa route. It costs nothing to bring it in for you to open a case and be in a loaner in the meantime
On a side note, the other part that seems to fail regularly on these cars is the drivers side motor mount. I need to replace that as well (which really means both sides) and my passenger CV boot is leaking. So that is why I'm trying to DIY as much as possible or at least buy the parts cheap online and then get my local indie to install it all.
But so will oe and arnott struts at some point. Just in 6 years or more.
I also had to replace the cv boot...and if you have a motor mount issue too...thats a lot of work
If the parts were available I would say diy is definitely diyable. But they're not really...and time when you can't drive your vehicle is more than just an inconvenience. so I would open a case and push to get mercedes to cover it.
And if nothing comes from that. Try the other option is sending in yiur struts.
I got a quote for another extended warranty and it is around $5-6K for 3yr/36K and I don't want to keep the car that long, so I figured it is best to pay out of pocket for these repairs and then sell the car in 2 years. Right now all the parts are running me around 1750 and hopefully I can DIY the struts and CV joints and I will pay my indie probably around 500 to install the motor mounts.
I paid 3000 for a maxcare warranty in 2013. It has paid out 7k this calendar year. Around 4k in 2017.
I diy some stuff...but the service dept usually comps oil and heavily discounts other service.
I diyed the sway bar end links recently. They also wear out quickly.
You have a newer gl then mine and so you obviously paid a Not so inconsequential amount most likely.
I got so angry in september when the door handle that was replaced fell off the car...I was so angry....
Also that same month the takata air bag recall was done and when I got it back there was incessant squeaking from the steering column. The tech has damaged it....and I was so frustrated. They comped the repair for the clock spring and shroud.
Brutal. 😡
I've also been looking at the gle....but I keep thinking when they come home for holiday....friends...girlfriends.....oldest two now only gave the last one....but that will change of course.
And ski trips and road trips.
Plus the towing is useful for mulch...
