GL550 1 bald tire?
The dealer put 4 brand new Conti's on my truck just before I purchased it last December. With 9000 miles on those tires, they are down to around 5/32nds. These heavy trucks eat tires quickly.
On the one passenger rear tire wearing more - can be rear alignment if wear started uneven - can be "active lane assist" if your wife has that feature activated - we have area's in my region which are curvy two lanes roads - where it is common to "cut line's" - and active lane assist would kick in and owner would steer/override...
Where you are at on the other side on remaining tread - and what is remaining on the fronts - would bring up two or four replacements - would advise rear alignment - and on replacement tire have the shop "bump up" tire pressure on new by about 2PSI and see if that handling is acceptable and will help a bit on tread life for the 2nd set..
I have had cases where have moved my "female" drivers from 550 to their next GL as a loaded 450 - gives them smaller wheels with taller sidewall - smoother for them..
