Intermittent Violent Engine Shake while Idling
I had a similar issue twice last year, it was very weird, it idle like old diesel truck. I used to put Chevron but switch to Shell and haven’t had the issue since.
Make sure the clamp is down and tightly sealed. This is the first cause for most of these symptoms.
Keep the beat !
2 days now and car not experiencing symptoms ... sorta notice engine is "smoother" ... but totally not expecting bad motor mounts ... hmmmmm ... we shall see
I had this same experience back in probably January? I had the car warming up while I was inside as it was cold out. I had the defroster on max, and when I got in the car to drive away is when it happened. You nailed it on the head when you said it shook violently as if it was choking. It scared me half to death to so I pulled over in my neighborhood because it felt like it was going to blow. I turned it off and let it sit for a minute and when I turned it back on I left the heat off the whole time. I froze half to death, but was worried it had something to do with the heat. I never could get it to do it again. The dealership couldn't get it to do it either. If it happens again maybe I will suggest the motor mount. I do have a 2014 diesel but it had never acted like this before. Thanks for posting!
