HID swap for GL450
Old Mar 7, 2019 | 07:57 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
HID swap for GL450
I bought a 2016 GL not long ago. Unfortunately, I wasn't thinking and didn't look for one with the lighting package (I can't believe HIDs aren't standard on a 70k car, but w/e). Anyways, I wanted to know if I could swap used HID units from another GL onto this truck. I had a 2015 ML350 and I tried replacing the halogen bulbs with LED bulbs but it was a ****ing nightmare, and none of the bulbs I tried would actually screw into the housing properly. I don't want to go that disastrous route again.
Old Mar 7, 2019 | 08:17 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Not without recoding. Most just perform an HID conversion. We have canbus kits that are compatible with your GL SAM if interested.
Old Mar 7, 2019 | 08:25 PM
JD101b's Avatar
What would a recoding take?
I'm not very comfortable with an HID kit as it requires a hard wire to the battery. Even if that wasn't the case, I've tried using three different types of LED bulbs in my ML, and not a single one would screw into the stock housing, even when every vendor assured me that it would work. I'm really not sure why there aren't H7 specific LED bulbs on the market.
Old Mar 7, 2019 | 09:25 PM
AZN Optics's Avatar
You'll need to find a shop with a STAR diagnostic system. You'd probably pay them as much as it would take having a shop install an HID conversion kit anyways. Our kit are canbus enabled so no need to attach to battery as it just plugs into existing wiring.
Old Mar 7, 2019 | 10:42 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I've run an HID kit on my old 164 GL for over 11 years and 200k+ miles. No seperate wire needed. Just plugs into the stock harness. Only use bulbs with metal bases.
Old Mar 8, 2019 | 07:57 AM
vivaitalia's Avatar
2013 GL450
Your boy AZN Optics will set you up ... I paired the Morimoto 6500k (50W) bulbs with his suggested 35W Ballasts ... I would've liked to have a 50W Ballast (but his preferred brand doesn't make one with Canbus Circuitry built in) ... so the 6500K (50W) Morimoto bulbs with the 35W Ballasts gave me a white (drastically more so than halogens), but when along the road with the newer cars HIDs or LEDs, they are not as white or bright ... but still it is a world of a difference compared to OEM halogens ... all LED retrofits I've tried have failed miserably, just no where near as bright as HIDs (even with my pairing above) ... you do need the H7 bulbs with metal base (not plastic) and I also had to glue the OEM clip ring to the H7bulb metal "flange" base ... and yes I drilled a hole through the dust cap ... after 5 years driving a 2010 BMW with HIDs .... still miffed that the GL came standard with halogens ... ridiculous. Happy Install ... knowing what I know now, wouldn't take you more than 30 minutes (except a few hours for the glue to set)
Old Mar 8, 2019 | 09:28 AM
JD101b's Avatar
And what about installing them in the headlamp housing? Like I said, I had online chats with three different representatives from three different companies that promised the bulbs they were selling me would easily screw into the assembly. None did. I spent hours trying to get the damn things in but they just wouldn't stick. It was/is a horrible experience. Do you guarantee that your bulbs will easily and properly fit the headlamps of my 2016 GL450 (or for that matter, my 2015 ML 350?)
Old Mar 8, 2019 | 09:29 AM
JD101b's Avatar
The bulbs I have are SUPER bright. The problem is, they won't screw into the stock housing.
Old Dec 2, 2023 | 08:04 PM
phchris2000's Avatar
2015 GL450
Hello
looking for a reliable retrofit HID for my 2015GL450
Old Dec 15, 2023 | 09:33 AM
dadirypanda's Avatar
Mercedes C250
I found these on Amazon. Not HID but LED for lowbeams that work with the weird mercedes headlight clips. Works in 2013 GL450. Worth a try as you don't have to mess with the HID ballast and wires.
https://www.lasfit.com/products/cust...rward-lighting
Old Dec 18, 2023 | 09:08 AM
JD101b's Avatar
LasFit bulbs were the only ones that fit snugly into the sockets on my ML. Every other bulb wiggled about, had to be held in with electrical tape, etc.
You're going to get better light output with HID's but I've yet to see an HID kit that doesn't have a flimsy base that is IMPOSSIBLE to fit securely in the socket. The lasfit bulbs for High and Low, plus a pair of LED's for the running lamps, will make a world of difference. The best part is, the color temperature is very close to stock. It doesn't look cheap at all.
Old Dec 18, 2023 | 09:24 AM
BlownV8's Avatar
They are out there. Just search for a HID bulb with a metal base. The fit is exactly as OEM with the metal base bulbs. If you are talking about an LED conversion bulb, that may be possible.
Old Dec 29, 2023 | 02:53 PM
Mercedes C250
Lasfit LED bulbs
I think the HIDs have a farther light throw than the LED's. Overall good for city use.
less mess is worth it
Old Dec 29, 2023 | 03:05 PM
JD101b's Avatar
Yeah...the LED's are okay (interestingly, the LED fog light replacement bulbs on my G550 put out WAY more light than the stock HID's) - definitely better than stock halogens but having the factory HID/LED option is your best option.
When I sold my ML I had replaced both high and low beams with LED's. If I had found an HID kit that wasn't a nightmare to install I would have gone with that for the low beams and LED's for the high beams.
