Trailer hitch installation..
Just buy a GL with the factory towing package. Seriously.
It will save you a mountain of grief, the install (including wiring) will be perfect, and the truck's stability control will have programming for when a trailer is attached.
There are dozens (hundreds?) of threads here about aftermarket towing setups. (It's one of the most common questions/regrets, along with headlight upgrades.)
You are not in that position since you have not pulled the trigger. Save yourself the hassle and get the right truck for you.
hoping someone with experience can chime in.
To install a MB hitch-kit-with-harness into a GL without a factory installed hith - will be $900-$1100 for MB hitch with MB harness - then "about" 8 full genuine shop hrs for install of that wiring harness.
On your "hitch shop" - frankly you shouldn't need to ever talk to them again - since what they told you is 1000% "bullsh*t" - they "don't trust" MB factory GL hitch - what a crock on that one - "aftermarket hitch that can be welded to the frame" - another crock - they 100%/positively/absolutely know nothing about the factory GL hitch system - if you challenge them on that - sit back while they invent some longer "bullsh*t" story... they would use a Curt hitch - bolt it on - put a couple of tack welds - then use a Modulite relay connection for the trailer electrics - something a U-Haul would do (without the tack welds) for like $420 total - but you will not have the factory electrical integration/safety-systems - and this "expert" shop will probably soak you for $800-$900.
Now - on your trailer brake controller - the MB factory trailer hitch system does have a wired-brake-controller connector in the driver area - but my opinion the "best" controllers out there now are wireless which means for controller install on GL side you just need power connection to the fuse block - that part with wireless is EZ-Pezzey..
The OEM hitch is also pretty good (I'd say one of the best on any unibody vehicle). If you look at Porsche or Audi, the hitch is attached to unibody via 8 bolts (4 on the right and 4 on the left). GL's hitch has those 8 bolts AND also 2 large support arms, that are bolted to the hitch at one end, and go into a recess in the uniboy at the other end and are bolted there. This makes for a stout hitch-unibody connection (unlike Porsche or Audi).
With OEM hitch you also have the computer reprogrammed and you get lots of goodies that you would not get with an aftermarket job. GL monitors the trailer and if it detects any sway it applies GLs brakes (independently at each wheel) to straighten out the rig. This is a major safety feature and you would not get it with an aftermarket install. Luckily, I've never had to use this this feature, but have heard its very effective.
Finally, are you really going to believe what an aftermarket hitch installer is telling you about your GL? GL is an expensive and complex piece of machinery and I am not sure ANY hitch installer would have a clue as what they are talking about. Welding a hitch would be a nightmare: You'd likely lose your warranty. You would have limited access to areas under your GL (what are you going to do if you must make a repair and the welded parts are blocking you? Remove the whole thing?). GL is not a domestic truck with a frame, its a fancy European uniboy vehicle. I would stay away from any aftermarket hitch installer.
Just plug your VIN into this website.
https://www.datamb.com
FWIW, the option code on my 2014 for the factory hitch is 550.
