Suspension Refresh Advice
Thinking it is time to refresh suspension components and I definitely can hear a clunk sometimes when accelerating from a stop (perhaps that's an engine mount?) Getting some pretty good vibrations in idle now too.
What components would you guys recommend replacing? Is there any need to replace the shocks on these or do you wait for them to fail? Is there any notification when the shocks fail or what would be the symptoms? I live in LA and every once in awhile I hit a pothole I can't avoid and it almost seems like something bottoms out but not sure.
I have a set of engine mounts on hand as I was just assuming the "clunk" was the engine mount but now I am starting to wonder about business and ball joints.
My plan I guess would be to get under there and look for problems but I'm wondering what are the most highly suspect items. And/or what are the items I should absolutely replace and which ones might be OK to check to see if they are good?
Stabilizer bar bushings
Stabilizer bar links
Engine and transmission mounts
Shocks only if you need them
Ball joints and tie rod ends only if you need them
I have driven several vehicles over 200k miles and it’s rare to need to change the control arm bushings.
Same comment for shocks. New shocks will be a noticeable improvement, but there is a wide window of tolerance on when they need to be replaced.
1. Arnott Reman struts ($360)
2. Arnott New struts ($340)
3. Used Mercedes struts ($250)
4. Cheap Chinese struts from eBay ($130)
Take note if the 'settling' is uniform or one end vs. the other. It may be trying to level the vehicle to compensate for uneven ground on which it is parked.
Having said that, I am confident my sedan is not supposed to "settle". It might be an SUV thing but sedans aren't raised or lowered like SUVs so I feel that possibility does not exist. When I turn off my engine, I can hear a clicking noise form the front right corner of the car, sometimes I hear a hissing sound like the struts are releasing air. But other times the struts hold their height. And sometimes, even after I start the engine, the car does not rise at all. If I start to drive, get a message saying "Car too low. Stop car". And other times, the struts go all the way up and the drive is REALLY stiff... I can feel each and every bump in the road.
Any suggestions?
Any suggestions?
Edit. I see you mentioned you have cheap chinese struts on your car. Get rid of that crap and install the arnott struts or the oe Bilstein ones. Rockauto has good pricing.
