Trunk Programing
Old Aug 26, 2019 | 10:53 AM
silvergl's Avatar
GL 450
Trunk Programing
My trunk is no longer automatic, after having a dead battery for a period of time. I replaced the battery, now it will soft close, but does not open or close with the fob. I found a procedure online to reprogram, disconnect the batter, reconnect, pull the button on the drivers door for 5 seconds and that should fix it. It does not, when you pull the door button, the motor sounds like it wants to do something, but no action.
any other thoughts short of going to the dealer to have it reprogrammed?
Old Aug 28, 2019 | 05:29 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Did you check the fuse?
Old Aug 29, 2019 | 08:17 AM
silvergl's Avatar
GL 450
The fuse on the battery is good. I suppose I should look for the other, good idea.
