Relay Diagram
Old Oct 24, 2019 | 08:28 AM
mexsix's Avatar
GL500
Relay Diagram
Does any one have a relay diagram available? The fuse diagram doesn't show relays for whatever reason. I am just trying to work out what the relay circled in red is for (from the engine compartment fuse box)? Cheers
Old Oct 24, 2019 | 04:12 PM
mexsix's Avatar
GL500
Originally Posted by Plutoe
That's a very popular relay used on many models and features from mirror heating to fuel pumps----therefore post your VIN for the correct application on your VIN
Thanks for the reply. My apologies I thought all the x166 relay diagrams would be the same.
VIN WDC1668732A231963
Old Oct 24, 2019 | 06:58 PM
mexsix's Avatar
GL500
Nothing is the same on MB models\year built and that is why the VIN is always used to source parts.
In any event the circled relay in slot S and is a wiper park position heater relay and slot J is the horn relay
Thanks mate
Old Jun 27, 2021 | 04:45 PM
Artem Arestov's Avatar
Mercedes-Benz GL450 2013
Also looking for the relay diagram
VIN: 4JGDF7CE3DA175337
Especially curious where the fuel pump relay located.
Your help much appreciated!
Old Oct 11, 2021 | 12:48 PM
DrkNyte's Avatar
2003 SL500 AMG (R230)
I have the same issue with my 2013 GL450. Were you able to find the relay for the Fuel Pump? I keep coming across references to the Fuel Pump Module. 1st question is; does this years model have both a Fuel Pump Relay and Fuel Pump Module? 2nd question; Where are they located? please be specific with Pics as the diagram that came with the GL doesn't show any info on the relays. I know for sure the fuse is good. So it's either the Fuel Pump, Fuel Filter, Fuel Pump Relay or Fuel Pump Relay Module. I need to narrow it down but I have an engine crank and no fuel pressure. Also, with key on I do not hear any clicking for the relay or humming from the fuel pump.
