AXE 22" Wheels
Stock wheel/tire (295/40/21) weight was 83 pounds - about 30% tread left
New wheel/tire weight is 75 pounds.
I will likely add 5mm spacers in front and 10mm spacer in rear to get them a bit closer to being flush
AXE 1AV ZX11 Wheels 22x10.5 ET40 Gloss black with Double Dark Tinted Face
Lionhart LH-Five Tires 305/35/22
Was there much/any difference in the speedometer reading as you went from 21" to 22". I see you went from stock 40 to 35 profile, maybe that compensated?
