The hose is circled in red
Hey guys, having a major issue here. This coolant hose cracked and I can't identify the part number. The even bigger issue is I can't figure out how I'm supposed to even get to this sucker to remove/replace it. What parts need to be removed? I don't want to have to remove more than necessary, but I know I gotta do what I gotta do. This doesn't look like it's going to be a lot of fun. Any input is GREATLY appreciated. Thanks fam!
Here's a link to a small vid of the hose, I know it's hard to see, apologies
It's actually just below the thermostat housing and appears to go into the engine block. The other end I can't really tell where it goes. Visibility is really limited in this area of the engine. If I could pull enough of it out of there I could get a part number on it, but the piece I was able to pull out (it broke out from being so brittle) doesn't include the part number on it.
so I got a ratchet down in there and was able to take off the spot where it connects to what looks like the engine block. But I can't seem to trace where the other end of the hose goes. Any ideas?
