m276 engine with 100,000 miles
Should I prepare myself for the following preventative maintenance?
Timing chain & tensioners
Poly V Belt
Water pump/thermostat
Anything else on the 100,000 punch list for the M276?
This car has been running well and is still under CPO warranty until 2021
Thanks,
engine air filter
spark plugs
engine oil and filter
cabin dust filter
brake fluid change
wiper blades
Poly-v belt checks are on the list, not replacement.
Nothing about water pump or thermostat, or timing chain.
Except for early models (pre-2014), timing chain problems don't show up often, or at all, on this site for the M276.
Thanks for the info!
So far we love this vehicle. It's sporty enough despite the 3rd row of seats
Thanks for that viewpoint. I'm hoping to get as much life out of this car as possible. Glad to know there's no real Achilles' heals in this model!
Brad does that go for the GL 550 as well? I have a 2015. Currently with 73K miles. Hoping to get to 100K or further. Only issues Ive had so far has been one of the Coil packs went bad causing cylinder 8 misfire. Replacement of the coil pack took care of the issue. I have extended warranty to 100K miles.
I regularly maintain this vehicle and do the services myself. I use OEM oil filters and Mobile 1. I have replaced the brakes, air filters, brake fluid. Going to do a coolant flush when it warms up a bit outside and will also be replacing the spark plugs soon. They make a special thin walled spark plug socket with universal joint that helps with this task. This spring I will change the transmission fluid.
I measure oil consumption and between the service intervals it uses 4 ounces of oil between oil changes which is nothing, so little it is very hard to even see that usage on the dipstick. If you can do maintenance yourself they are really no more expensive to maintain than any premium vehicle.
These vehicles are well put together and if maintained well I don't see any reason they won't easily run to 250K of highway driving.
Thanks!
Third set of plugs
Third engine air filter
Second set of ignition coils/boots
Second poly-v belt
Oil changed every 10k miles
No oil in harness
No leaks
I am targeting 200k miles for this vehicle, and intend to change components that "shouldn't be changed" per MB. Four examples that have been completed are the poly-v belt, transfer case oil, front axle oil and rear axle oil.
I just checked my liftgate seal tonight and so far it looks OK. It doesn't seem like a high occurrence failure, but it's a nasty one.
Not many (any?) reports of taillamp gaskets leaking on 166 which seems common on 164. There are fewer or no electronics in low-lying locations in the rear of 166, unlike 164.
Looks like the dealer charged me for 9 liters of oil. It is a fill to overflow process so the precise volume inside the gearbox is less than 9 liters.
https://mbworld.org/forums/gle-class...report-12.html
I replaced the Turbo coolant lines at 78K, all fluids in all places (trans, diff, etc.) changed as recommended thru MB Service Intervals. I use the Liqui Moly flush and additive at oil change intervals, read good things about those products so why not give them a try. We got new tires and wheels at 81k and the car is cleaned on a regular basis. I run Lucas Fuel treatment in the car often and has helped gas mileage and I've read where it helps to protect the cylinder walls from getting scratched, I also run 93 octane on every fill up
Just now starting to get AC issues with the Drivers side, the Passenger side stays cold but the drivers side is having issues. Not sure if I need to change the freon in the car or if there is a temp sensor of blend door actuator going bad. Any suggestions or recommendations would be appreciated. The Center console lid on passenger side keeps flipping up, need to glue down a couple of magnets to fix that. Other than those issues the car runs great and looks fantastic, I'm a poor-boy and do all the work myself so we plan on having the car well into the 1/2-million-mile range with any luck!!
Chad
I just purchased the same "kit" from their parts department and they said that only 6 liters are needed to change (to flush, which they do not recommend at least for my car, 10 liters would be required).
