X166 Door Soft Close Reset
Old Apr 28, 2020 | 04:13 PM
M070552's Avatar
GL 63 AMG
I have a 2015 GL 550 with the door soft close feature. This has stopped working on the drivers side door, and a google search turns up a safety system actuation as a possible cause. Before I go to the trouble of trying to replace the soft close mechanism, I was wondering if there was a DIY way to try a reset to see if this is is the issue? The only things I’ve come across say a dealer has to do it, so I don’t know if it requires special software or if I could do it by pulling and reinstalling a fuse or finding it elsewhere in the vehicle settings?
Old Jul 21, 2023 | 03:09 AM
ABadran's Avatar
2016 Gl350
No replies at all?
Any updates my brother? I have the same thing on 2016 gl350.
Old Jul 22, 2023 | 07:23 AM
RA122924's Avatar
Originally Posted by ABadran
No replies at all?
same here 2013 gl450.
Old Jul 29, 2023 | 02:51 AM
ABadran's Avatar
2016 Gl350
Fuse diagram is so inadequate. I'm new to Mercedes and I'm not enjoying the lack of info on almost anything I research.
Old Jul 29, 2023 | 07:21 AM
chassis's Avatar
2017 GLE350 4MATIC
Buy WIS/EPC for approx $20 on ebay. Buy a XENTRY system, searching this site will steer you to a provider.
With WIS/EPC and XENTRY you will have everything a dealer service tech has at his disposal.
Old Jul 31, 2023 | 08:09 PM
Big Coupe's Avatar
CL550
M070552, did you find a solution? I am now in the identical situation.
Pump must be ok if passenger side functions? So what then? Thanks eh!
Peter
Old Aug 15, 2023 | 11:36 AM
lexnoir's Avatar
2022 SL 55 AMG, 2020 AMG GT 53, 2015 GL 550
Same issue
Same. Driver side door only.
Old Aug 15, 2023 | 12:02 PM
ABadran's Avatar
2016 Gl350
Yes, working on those right now. Thanks man
Old Aug 15, 2023 | 12:14 PM
ABadran's Avatar
2016 Gl350
Fixed
Solution: while the car is "on" not necessarily with engine running, disconnect all power to door module then reconnect.
Hopefully all of you guys with the same issue can fix it this way.
First of all, mine, and likely yours, was never broken. The actuators do break though. So you have to reset correctly to be sure before changing an expensive good part. It just had one of those electronic blockages that happen to every car but then you turn the car off then on and every thing is fine. That's not how it works with Mercedes though. Once you have one of those, the module needs to be reset. So I would disconnect and reconnect the battery but in X166 I've been told that's not an option, but I'm still doing my research.
​​​​​​So I took the door panel off initially to get the actuator out and diagnose the issue. But thought that before removing the window glass and all those other things to get to actuator, why not reset the door module first. People here said to do that, so I did and it worked.
Now it would be more ideal to disconnect the fuse to the door module but the diagram doesn't show it. I'd love to get the fuse if someone knows it.
Thank you to the people who talked about power reset to door. The car felt incomplete without this.
Old Aug 15, 2023 | 12:58 PM
lexnoir's Avatar
Thank you for the feedback
Can you give more details/instructions on exactly how you reset the power?
