Oil in engine harness
That's why I bet there are much more cases of this issue, but it doesn't always cause problems or a check-engine light. So you can run like this for a while, but not great for the ECU/connectors/sensors.
How many people open up their camshaft sensors and ECU to check for oil=)
Zero idea of that grease helping or not. But if it doesn't hurt, why not try it.
The oil insulates pin-vs-pin. It creates a film barrier, for example, between cam position sensor pins and the corresponding harness pins. Or, for example, between pins on the harness and the corresponding pins at the ECU.
The film doesn't need to be much. Intermittent loss of contact is enough to cause a problem. A test that I haven't seen people do here is to measure continuity and resistance between the ECU end of the harness and the sensor (cam position sensor, cam magnet). While interesting, it wouldn't rule out intermittent loss of electrical contact, and it would not indicate whether or not contact was being made when everything is connected. Star/Xentry/DAS could help with this.
Dielectric grease might help, or might make things worse. It has been demonstrated that MB harnesses are not wick-proof. The question is will grease wick as readily as oil. Likely not, but hard to know for sure.
Replacement of the offending sensors and harness, and ECU, is the highest confidence solution, and most expensive. The hardest DIY step is coding the ECU. A good relationship with an Indy shop could help with ECU coding.
M278
M157
M272
M276
And probably others. The root causes are leaking cam magnets and cam position sensors, approximately around the early 2010s or so.
All contacts in connectors are "spring loaded"... Which makes it indifferent to oil film... As a matter of fact it used be recommended to put some of electrician dielectric grease into connectors some time ago to prevent water damage...
The secret is quite simple - plastic used for wiring insulation... "Biodegradable" crap or whatever they still use... Oil + vibrations accelerate wear and damage leading to shortcuts....
Been rebuilding xenon headlights on other MB project from 2009... All insulation crumbles by itself...
My 2013 ML 550 (03/2012) had the old part numbers but my 2015 S550 (11/2014) has the newer cam magnets, still need to confirm whether it has the old or newer cam sensors - I assume the newer.
Maybe there was a production cutoff for these sometime in 2014?
My 2013 ML 550 had the old part numbers but my 2015 S550 (11/2014) has the newer cam magnets, still need to confirm whether it has the old or newer cam sensors - I assume the newer.
Maybe there was a production cutoff for these?
Two cam position sensors leaking, oil in harness and has reached the ecu.
2015 car
MB / WIS repair procedures seek the shortest time solution, generally. One example of this the is the M276 NA spark plug change procedure, which WIS calls for removing the intake manifold but this in fact is not required. I can see how intake manifold removal would be a faster spark plug change, than not removing it.
Study harness and engine diagrams, and look at your engine to see how you would release all of the harness connectors with the engine in place. At the rear of the entire the dash bulkhead likely needs to be removed and possibly connectors accessed from below the vehicle at the transmission bell housing. This might be for items mounted to the rear of the cylinder head and block such as crank position sensor, vacuum pump, fuel pump, PCV, etc. There is quite a bit of stuff back there.
No codes or lights as yet but been experiencing the sensation of a sudden thump or jolt throughout the car on acceleration on partial throttle that is not associated with a gear change.
Only problem is that it doesn't do it all the time.
My thought is that the injection molded plastic housing of the sensor has cracked due to fatigue (vibration and chemical attack) and age, and is allowing oil inside the sensor from where it migrates through the connector pins and into the harness.
