Oxygen Sensor Replacement
I was wondering if anyone has the WIS for replacing the Oxygen Sensors on the M278 Engine. Theres a check engine code of P013E00 and dealer says that its the oxygen sensors that are faulty.
On many (most? all?) vehicles the upstream sensor is readily visible and removable from above in the engine bay with little to no drama. The downstream sensors are generally access from below, and are more difficult but doable nevertheless.
I had that happen on my 2013 GL450 a year ago and wiggling the connector fixed it - the light/code never came back.
If that doesn't work, the replacement is certainly doable, but get the proper oxygen sensor wrench, it will make the job a lot easier.
