Got slight vibration on steering wheel on idle after performing oil and transmission
Old Apr 25, 2021 | 12:06 AM
wakk350's Avatar
GL350
I performed the oil and transmission fluid change service. Started feeling slight vibration on idle on the steering and generally on the dash after the service. It was not there before.
I have 2013 gl350 with 105k miles....the transmission fluid was very dirty as if it never had any change...total oil came out was 4.5 quarts and I put back 5 quarts back....the capacity specs say it should way more than that....so now wondering did I do something out of normal that caused the idling vibration????
Old Apr 25, 2021 | 01:31 PM
Packrat555's Avatar
2013 GL450
did you check level on the dipstick? oil change should be 8.5 quarts
Old Apr 26, 2021 | 12:15 AM
wakk350's Avatar
GL350
I had first put 8 quarts, the dipstick level was about half point between the min and max marks....then I poured on more quart....the level is at the full mark next day before the cold start....so total 9 quarts with filter change.
