Rear Washer Fluid Jet Leaking (Help)
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
While using my rear windscreen washer jet, I noticed that it is leaking inside the plastic housing (by the high-level brake light) and then leaking into the vehicle interior.
I suspect that either the pipe is popped off a mounting point or there is some potential holes in the pipe itself.
Either way, any idea how to remove the rear plastic trim in the the boot hatch so that I can take a look at where the leak is coming from?
I suspect it would be an easy fix and not worth the £180 charge just to assess the issue.
