Command Not Turning On 2014 GL450
Old Aug 6, 2021 | 03:57 PM
2014Gl450!'s Avatar
2014 GL450
Exclamation Command Not Turning On 2014 GL450
Hi. Yesterday i was driving my 2014 gl450 everything worked fine from the 360 camera to the cd player while I was driving to my destination and as i pulled into the parking lot the command screen booted a couple times showed the warning that says not to look at the navigation while driving then went black I turned the car off and left when i came back and turned on the car the command screen in the middle did not work at all neither did the cd player it was all blank i also got the blind spot monitoring inoperative warning the heated seat buttons and the climate control works fine and the car drives normally too. I live about 200 miles away from the closest Mercedes dealer so that is not really an option for me unless its very very important.
Old Dec 8, 2021 | 06:21 PM
TNMB2014's Avatar
'14 GL 450
Were you able to every find a fix for this issue? I'm having the same problem. Swapped and checked all the fuses that correlate to the command unit and no change. I'm thinking the battery might be my next option.
