AC compressor discharge line weeping oil?
Old Aug 8, 2021 | 02:19 PM
chassis's Avatar
2017 GLE350 4MATIC
Has anyone experienced this? I just did a regular underhood inspection and it seems like the refrigerant discharge hose is weeping oil at the compressor end rubber-metal crimp.
The MB part is $53 and would take me less than 1 hour to replace.
What is the going rate for dealer or indy AC system evac and recharge?
Cross posted on all *166 sections until the mods consolidate these nearly identical sections. I used the search feature and it didn't produce a useable result.
Old Aug 8, 2021 | 03:58 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Easy thing to do. Buy vacuum pump from Harbor Freight for 89 dollars https://www.harborfreight.com/25-cfm...ump-61245.html. Buy AC gauge from Harbor Freight for 69 dollars. Buy cheapest freon from Walmart. And check YouTube
Old Aug 8, 2021 | 03:59 PM
chassis's Avatar
2017 GLE350 4MATIC
@arsupisemnet Thanks!
