Heating issues(again)... desiccant bag, flush again?
Old Yesterday | 08:04 PM
Tony38's Avatar
2015 GL450
[QUOTE=ChicagoPete;8497351]Hi,
New member here.
GL went into the dealer in early Dec... all 4(?) cooling lines to the turbos needed replacement.
That got fixed and picked up the car and had no heat. Said the desiccant bladder ruptured:
  • Replaced coolant bottle
  • Replaced heater pump
  • Replaced thermostat
  • Flushed entire system
Worked great for 3 weeks. Same issue returned. Minimal, luke warm heat.
And, I can literally see/watch the temp gauge fluctuate from 80-97, up and down while driving. Temp sensor bad?
Can the replacement coolant bottle with new desiccant bag rupture again?? How would I visually check if the bag is ruptured?What ended up being the issue? I was just quoted 12K for the exact same thing on a 2015 GL450
Old Yesterday | 08:05 PM
Tony38's Avatar
2015 GL450
Having the same issue
I have a 2015 GL450 and Mercedes quoted me the same price. What ended up being the issue and how did you get it solved?
Old Yesterday | 09:49 PM
Chrome988's Avatar
2012 MB R350 Bluetec
If your dessicant has burst, the dessicant contents are plugging up your heater core. This needs to be replaced. It's a HUGE job, involves complete removal of the dashboard.
