What is this leak now?
I would choose to ignore it until it becomes a noticeable problem.
As mentioned already, regardless of how you handle it, you almost certainly will have to replace the entirety of the plastic coolant lines that run in front of the engine and to the turbochargers, as they
I need some CPS's as well, so it made sense to order and overnight. I have a disdain for my local dealer.
I would clean everything up real well, brake cleaner maybe and keep an eye on it every day or so until you find the leak. I would not ignore it, I have the worst luck of fatal failures at inopportune times.
Anyway brake clean it and see if it is leaking again before replacing, because for me it look like oil spray from belt which means could be oil leaking on belt somewhere else. Do not look like coolant.
