GL 350 W166 Airmatic Compressor constantly running
The vehicle has another symptom when it is being driven on icy roads the rear end is very unstable, the stability program is often called upon to keep it from skidding (applying brakes to one wheel etc), During testing under the slippery road conditions I shut off the stability control program thinking perhaps it was causing the instability however the instability of the back end continued so for now I ruled out the stability control as the cause. Our vehicle has cross wind assist and auto levelling. I though of mine is that something is telling the suspension compressor to operate and the the ride height is being adjusted and this is creating the instability on slippery roads.
I have asked them to try another relay - perhaps the relay can stick? I don't know
The Indy Shop is not certain what to do next- We get no codes, the vehicle does not droop at all even when parked for several days and driven with the compressor disabled (compressor relay removed) .
I'm still dealing with the exact same symptoms as you describe related to your airmatic suspension compressor. Replaced the valve block and then the compressor, but no change. Vehicle can sit for weeks and does not settle, so I don't believe the air springs are leaking. Less than 60,000 total kilometers (36,000 miles) so I can't imagine things are worn out? I'm worried my replacement compressor will eventually wear out, again, because it seems to run constantly when the vehicle is in motion. Like yours, it seems to pressure up just as the vehicle comes to a stop and shut off, but then starts running again once driving.
I also had the same problem you describe with driving on icy roads. Did you happen to have your GL aligned before this started? The reason I ask is that I did (at one of the local MB dealerships) and that is when my GL started feeling very unstable in the rear while driving on icy roads. It was perfectly fine before the wheel alignment but was almost undriveable afterwards. I should note that the only reason I took it in for and alignment in the first place was because the steering wheel had been slightly off center ever since new and I finally got tired of it... Anyhow, I looked at the alignment printout (which I had asked the dealer for when the work was done) and noticed they made a large adjustment of toe on the rear axle to bring it within "spec". I didn't understand this because it drove very well before hand (other than the steering wheel being slightly off center) so why such a large adjustment was needed was beyond me? I took it back to the dealer to check the alignment which they confirmed once again was "in spec" but there was no way I was going to be able to drive it the way it was, so I made them adjust the rear axle "toe in" setting back to near zero (where it was initially). After doing that, it drives perfect once again. I don't understand why the factory specifications calls for so much "toe in" on the rear axle, but it is wrong and definitely affected the icy road driving characteristics of my GL in a bad way.
Regarding the instability. We have not had the alignment completed but will have it checked. Since it is summer it is difficult to know if we have the same problem or if it was related to the compressor/ride height sensor issue and now resolved- it was only noted on icy roads. Thank you for sharing your solution.
