Gl550 sway bar link torque specs
Old Jul 31, 2022 | 06:51 PM
Htownbenz's Avatar
2012 Mercedes e350 coupe, 2014 Mercedes gl550
Am replacing sway bar links
need torque spec for the bolt , and the nut .
2014 gl550
appreciate it
Old Aug 2, 2022 | 10:05 PM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
See attached from WIS for GL550. Torque specs are on the last pages. Hope that helps
Old Aug 3, 2022 | 02:10 PM
chassis's Avatar
2017 GLE350 4MATIC
The attached shows WIS for Active Curve and does not include torque specs for base stabilizer bar non-Active Curve. It’s reasonable to assume torque in the stabilizer bar and therefore force on the stabilizer link and therefore torque in the link fasteners will be higher for Active Curve than they are for base stabilizer bar.
It would risk stripping the fastener threads to torque a base link using Active Curve torque specs. I don’t have the base torque spec at hand, hopefully someone can post it.
Old Aug 3, 2022 | 02:22 PM
Htownbenz's Avatar
chassis
Damn good catch, yeah I don’t have active curve system
Old Aug 3, 2022 | 07:25 PM
Mikey178's Avatar
Sorry, that was not clear whether you had active curve or not.
WIS only shows with Active Curve unless I'm not looking in the right spot. Tried both ML and GL 350, 450, 550 but all had only with Active Curve
Old Aug 3, 2022 | 10:24 PM
chassis's Avatar
2017 GLE350 4MATIC
Need to enter into WIS a VIN from a base model. Because the WIS posted to this thread specifies Active Curve, and not all models, there must be another WIS document for non-active curve.
