2015 GL63 - Door Clicking/Cracking Noise When Opening/Closing
Old Aug 2, 2022 | 05:14 AM
cyberdyne's Avatar
The driver side door of my 2015 GL63 makes 2 - 3 noticeable clicking noises when opening or closing the door. I have tried aerosol white lithium grease on all the obvious visible pivot points with no change.
Nothing changes on the visible hinge side of the door when opening or closing it and nothing feel loose.
I have read that on some models there is a small (7mm) adjustable bolt on the bottom of the lower hinge but I do not appear to have this on any of my hinges and there is no traditional check strap as in my W126.
It’s more of a loud embarrassment than a functional issue at this point but it doesn’t sound very good and with these cars than can only mean potentially expensive later on.
Any ideas?
Old Aug 2, 2022 | 05:00 PM
oldmangrimes's Avatar
GL450
Have you tried an automotive stethoscope? They are very cheap to buy, and may help you pinpoint which hinge (or cable?) is making the noise.
Old Aug 2, 2022 | 09:27 PM
mtm's Avatar
mtm
gl450
I've had this on my 2013 GL450 since new - almost like 2-3 stages of opening the door. I just got used to it.
Old Aug 3, 2022 | 08:17 AM
mikeolive's Avatar
GL350, Audi A3 TDI, VW Beetle TDI
I've got the same thing going on with my GL350--driver's door only. I've also lubricant sprayed hinges and slides with no apparent improvement. I'm not aware of the "small (7mm) adjustable bolt". I'll check and repost if I have it.
Old Sep 14, 2022 | 11:13 PM
Eugene74's Avatar
2015 GL 350
its not gonna work
Old Sep 15, 2022 | 11:36 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Don't open
Old May 14, 2024 | 02:22 PM
fehrenbach's Avatar
2007 R350
This happens on my R350 as well. I noticed it started after a gust of wind blew the door open hard once. I am guessing there is an internal piece, like a sleeve, that has malfunctioned or failed prematurely due to the trauma. But I am also searching for what the fix is.
Old Jul 16, 2024 | 07:48 PM
Elwood P's Avatar
glk 250
Had a door hinge clicking / clunking when opening and closing.
This is remiscent of the more normal door mechanism that involves a spring and a couple of reluctant rollers.
The hinge on my E350 2014 is nothing like that arrangement as the detent and spring mechanism is housed inside a metal cylinder.
There is a bolt on the top of the larger lower hinge, the source of issue.
If you remove the plastic beauty cap and (13 mm) bolt, don't worry, noting is going to came apart, or it shouldn't, it provides an opening for lubrication access.
I drizzled some 90 W Gear Oil into it and put the bolt and cap back on.
It took a couple of days for the lube to work it's magic, but it did and the grinding is gone. Cheap fix, you will need to wipe up any oil that drips out.
I also tried squeezing some white lithium grease into the opening and used the bolt to push it through. That certainley didn't hurt the process.
Old Oct 27, 2025 | 02:47 PM
psh2018's Avatar
2015 ML350
Elwood, can you elaborate on this? My hinges have been driving me crazy (have another thread on this). This is a gold mine if it solves these 'non lubricating' hinges.
- did you feel the need to support that door at all ?
- was the bolt removed completely?
Guess I'm a bit nervous about the process. I actually just bought new lower hinges for both sides that were not too expensive - $187 including shipping. If this process works then I would save the painting and installation costs and downtime.
Thanks Elwood for any additional info you can provide.
Old Oct 30, 2025 | 06:35 PM
psh2018's Avatar
2015 ML350
Wanted to add the video of my ML350 door hinges. The sound in the video is amplified, so not that bad, but still noisy.
File Type: mov
Old Nov 2, 2025 | 10:53 AM
tullymars's Avatar
2015 GL450 + 2017 E400
We've got the same issue on the driver's side door in our 2015 GL450. Drives me crazy. Started taking the door apart to figure it out, and my best guess is there is some kind of broken weld interior to the door near the hinge. I stopped short of taking the whole door apart to find it and now just live with it, but I am curious if anyone dug into this further.
Old Nov 4, 2025 | 07:54 PM
psh2018's Avatar
2015 ML350
Don't know about your model, but mine is a ML350 and the noise is in the hinge itself - - nothing to do with inside the door, no need to take the door apart. Really is baffling that there is no ability to lubricate the hinges as part of regular maintenance. It would be great if Elwood P would chime in and confirm how his method worked - - again, I'm a little hesitant to start loosening the bolt . . . . 50 years ago I wouldn't have thought twice about doing it, now . .
Old Dec 11, 2025 | 07:40 AM
psh2018's Avatar
2015 ML350
Resolved: I went ahead and got new lower hinges. Took them to a body shop for painting, and when done, took the car in for them to be installed.
Hinges: from MB Parts Source, best deal I found, right and left bottom hinges and shipping - $187
Paint / Install: local shop, $453
Total: $640
Now the doors open with complete silence!
Old Jan 18, 2026 | 10:20 AM
qxron's Avatar
2021 GLS580
Total: $640
This is the only way. I’ve owned 4 X166s and tried everything. Read that was the only fix unfortunately. I just learned to live with the sounds…
