Lower Ball Joint Replacement
There are two nuts holding the ball joint. The top one is a 24mm nut and the bottom one is a 46mm nut. For the top, you will need a torx bit (I believe T30, but I will double check) to insert into the top of the shaft to stop it from spinning. Because the spindle is in the way, this is only accessible if the control arm has been dropped and you can maneuver it to angle it to the side of the spindle in order to get the torx bit into the top of the shaft. For the bottom nut, I broke it loose using a 46mm socket and then used a vice grips on the rubber boot to stop it from spinning (only because I knew i was replacing the ball joint). However, the proper way is to use a 46mm wrench and hold the bottom of the ball joint with a 16mm hex bit.
Hope this helps anyone looking to do this. I will start a new thread with a write up for the whole process of replacing the control arms, although it has been a pretty straight forward process.
FYI - I ordered replacement ball joints from Eeuroparts and they sent me the Bison brand (which is also branded Moog on the label) ball joint instead of the Lemfoerder version and the bottom threads are not the same as the Mercedes ball joint and it did not come with its own nut, so it is worthless. I would stay away from the Bison ball joints. I will update on the Lemfoerder... which I believe is the OEM. The Bison control arm seems to be of good quality.
