Oil leak from the engine front cylinder head covers.
Old Mar 3, 2023 | 06:33 PM
aslanc's Avatar
GL450
2013 w/80K miles. GL450.
I took the car in for a steering wheel recall work, and was told that there is an oil leak from the engine front ylinder head covers. This needs to be resealed.
How common is this problem and what is the reasonable estimate for this repair?
Thanks.
Old Mar 4, 2023 | 09:06 AM
mtm's Avatar
mtm
gl450
If they mean timing covers - then yes, oil leak there is common with m278 engine. Sorry, can't tell you what the reasonable cost would be because mine were done together with many other things - turbo coolant lines, thermostat, water pump etc, so they had easy access.
Old Mar 4, 2023 | 10:26 AM
chassis's Avatar
2017 GLE350 4MATIC
Thanks.
Common defect from the factory. Resealing is not strictly a “must” but the leaks make a mess and there will be loss of oil over time. Suggest you get them fixed. Dealer is a ripoff. Indy can do this job.
