GL450 RR door lock
Old Jul 5, 2023 | 10:55 AM
Netseller's Avatar
GL450
GL450 RR door lock
Hello,
I have a 2013 GL450 that I have noticed the the door lock does not work on the right rear door. The lock works as in the locked/unlocked indicator does go up and down but in order to have the lock actually "lock" I have to press down on the indicator with a small bit of force (it moves about 2 mm). Is this just a lubrication issue or is a new actuator needed? If either is the case is there a guide I could refer to? Any help would be appreciated. Thank you.
Les
Old Jul 5, 2023 | 02:35 PM
Panzerknacker's Avatar
GL 350 Bluetec
Fairly common issue. Likely needs a new actuator. Mine had this problem and it was fixed on an aftermarket warranty.
https://mbworld.org/forums/gl-class-...ng-locked.html
Old Jul 5, 2023 | 03:02 PM
Netseller's Avatar
GL450
Thank you, much appreciated!
