Oil Additives
Old Sep 29, 2023 | 09:35 PM
Ryanoscerous's Avatar
2016 GL 450
Oil Additives
Normally I wouldn’t even bring think of adding anything to the oil, but it seems like there is a problem with these engines on cold starts. I have the M276, and it’s pretty noisy on the first start. It doesn’t seem like MB even has a good answer. I’ve read all the threads. Asking the community for any success stories.
Old Sep 29, 2023 | 11:51 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
the lifters on a lot of cars, particularly higher performance ones need a few cycles before they are hydraulically filled with oil and the bearings have their cushioning film restored. what youre hearing is the chatter of the timing chain,bearings and/or the lifters before the hydraulic tensioner/lifters become pressurized to their normal operating status. everything in the tengine sort of "floats" and doesn't touch each other due to an oil film protecting everything which can drain back and deplete over time when the car is parked. Cars that store oil in the head have their own problems, theres always a compromise.
oil can/will influence the effect if you have thickened oil that doens't flow well you can have it be louder or last longer but you can't really fundamentally "cure" it.
You can always give amsoil a try and see if that helps. I personally use it in the fleet cars/customer cars here and I'm pleased with the amount of start up chatter on our cars. Amsoil themselves do not recommend using oil additives since it throws off the ph and chemistry of oil in addition to potentially compromising its ability to neutralize acid, cool itself, and last the full oil change interval without cooking off, thickening, or becoming acidic.
Alphaeuropean.myamsoil.com
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Sep 30, 2023 | 11:40 AM
bwaldmer's Avatar
2015 GL550
This is why I was told when I was a teenager to never start revving the motor on a car until a minute after you first start it.
Old Sep 30, 2023 | 02:31 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
I would not add a thing to Mobil oil you suppose to have in the engine.
