Airmatic
Old Oct 2, 2023 | 11:02 AM
poptopclk's Avatar
2017 X166 GLS550 & (R230) SL550 2007 & 2012 S550
Lightbulb Airmatic
I had an issue that APPEARED to be a bad strut. Xentry couldn't raise it or lower it, all the other 3 corners worked normally.
I ended up replacing it and the SAME problem still remained !
I then replaced to Valve Block and the issue was resolved.
The take-away, replace the VALVE BLOCK 1st it is cheaper & easier than a strut replacement.
Old Oct 3, 2023 | 02:52 PM
Panzerknacker's Avatar
GL 350 Bluetec
If it was not sagging over time then I would not assume a leaking spring.
