Air suspension relay
Old Dec 29, 2023 | 01:46 PM
Black2010's Avatar
2014 GL450
Hello I have a 2014 GL450 and the rear is sagging I replaced the air valve block, fuse and the pump the rear still won't inflate any suggestions on what else I should try would be helpful I was thinking of replacing the air suspension relay but for the Life of me I can't find out where the air suspension relay is located. Does anyone know where the air suspension relay is located on the 2014 gl450 if you have a picture that would be helpful thanks in advance for all your help.
Old Jan 6, 2024 | 07:21 PM
acetaylor's Avatar
07 C280 4matic, 2014 GL450, 91 VW Vanagon
Ditto what he said. I've replace the compressor and Arnot says the relay must be replaced and sent one with the compressor but I've searched and searched and cannot fine the location for the suspension compressor relay.
Old Jan 8, 2024 | 12:20 PM
oldmangrimes's Avatar
GL450
https://fuseandrelay.com/mercedes/166-ml-gl.html
Search for Relay T for airmatic. I think it's under the cabin air filter on the left side of the engine bay, you have to remove a couple things to get to the fuse/relay box.
