X166 Control Arm hitting LCA
Old May 4, 2024 | 10:49 AM
Diego E Tudor G's Avatar
2012 Mercedes S400
Hello everyone, I have a x166 in the shop that has a suspension clunk, inspecting it found the LCA and Sway bar are contacting because it has slid to the drivers side causing it to be off center. I wanted to know if anyone has had this issue before. Right now Im simply going to loosen bushing and bring it back to alignment but Im afraid it will happen again, my suspicion is that the bushing are worn allowing movement but as my experience with my S400 MB wont simply sell sway bushings but rather the whole Sway Bar, seem uneccessary as its not damaged.
The truck has ~100k miles and carfax shows long list of records including front suspension work and engine removal at 23k
Anyways any info would be great
Old May 18, 2024 | 02:39 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Most of the time this happens when on of the suspension struts leaks and goes all the way down. It will make the sway bar slide to one side. Just loosen the sway bar and reposition.
