Glow Plug error after oil cooler seal change
So I recently changed the oil cooler seal on my 2013 GL350. It took longer than expected and I had to redo some stuff, but now it's all back together and looks to be leak-free. Two things though:
1. Now when I start the car I get a glow plug warning - I see in some cases the recommendation is to change the glow plug module, but could that warning be the result of something else I did?
2. I get a high side error on the intake manifold - I'm guessing I need to hook something up and recalibrate it or something? It was running disconnected for a little while, but I reset the codes after I reconnected it.
thanks!
thanks!
