Module Mayhem
So adblue module was replaced and now I get an intermittent dead car. Central locking is out. When I put the key in the ignition and turn it the heat/AC doesn’t come on. Car won’t crank and has a ton of faults. “3rd row seat not locked” “passenger side airbag” “traction control” and some others. I can probably get a list if that helps narrow it down.
Sometimes the car starts up and runs without issue or warnings, other times it is a dead paperweight. Even plugging it into my other car via jump cables and charging the battery a ways and trying again doesn’t resolve it.
Anybody out there have a good idea where to start? Seems possible that the front SAM is intermittent and failing since the symptoms cover so many problems and *if* the modules do wake up then the car works.
A picture or how-to access the SAM would be awesome.
