Need Help with P0018 Code on 2016 GL450 V6
Old Jul 23, 2024 | 11:09 PM
Toniom5's Avatar
2016 gl450 Mercedes
Hey everyone,
I'm having some trouble with my 2016 GL450 V6. The check engine light came on with a P0018 code. I replaced all four camshaft position sensors and cleared the codes with a scanner. The car started fine after that, but after driving and turning it off, it took longer to start the second time and the check engine light came back on.
After reading some forums and watching videos, I saw recommendations to replace the crankshaft position sensor. I did that, but unfortunately, the same issue persists. The car is back to square one with the same P0018 code for the camshaft position sensor on bank 2, sensor A.
Any feedback or advice would be greatly appreciated. Thanks in advance!
Old Jul 24, 2024 | 07:06 AM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Cant you just google it https://www.carparts.com/blog/p0018-...nk-2-sensor-a/
Not a sensor - adjuster, adjuster magnet, timing chain, etc
Old Aug 25, 2024 | 11:18 PM
VarunBajaj's Avatar
2012 E550
Originally Posted by Toniom5
Hey everyone,
Were you able to fix this? The same thing happened with me. What was the solution?
