Need help****** GLS550 Starter replacement
Old Sep 14, 2024 | 02:23 PM
JPGLS550's Avatar
2009 C300, 2017 GLS550
When I try to start the car and push the button it won’t start, but I do hear a loud click. I changed the battery and confirmed the starter relay is good. Could it be anything other than the starter? I went ahead and bought a new starter, but when under the car it looks like it’s going to be a nightmare to get to. Anyone change one and have some tips and tricks?
Old Sep 14, 2024 | 05:42 PM
RollTideW163's Avatar
2014 GL450, 2006 S500, 2003 ML350, 1996 C280 (Prev 1995 C220, 2002 CLK320, 1980 300SD Turbo)
Did you verify the battery is indeed fully charged and throw it on a charger? A lot of new batteries may have been sitting on a shelf and you'd be surprised how many batteries sold are not ready to use.
Old Sep 14, 2024 | 06:37 PM
JPGLS550's Avatar
I tried starting it once I installed it and the same click. I charged the battery for two days, and the same thing.
Old Sep 14, 2024 | 08:59 PM
Can you provide a little more info on the background here? For instance, when was the last time the vehicle started successfully, after what period of time did the no start issue occur, how old was the previous battery, etc. The more info of this nature can determine what could be occuring.
It's really rare a starter fails, it is usually an electrical or a fuel delivery situation.
Also, do you have access to a scanner or something like a DAS that can pull some info? That would be helpful to determine what's up.
Old Sep 15, 2024 | 03:36 AM
streborx's Avatar
Top Answer: 1
G550
Are you hearing a single click or a repetitive clicking for as long as you keep the start button pressed?
Old Sep 15, 2024 | 12:13 PM
I realized I didn't answer your question - and I can't attach a PDF for some reason so I'll try and PM you the procedure.
Old Sep 15, 2024 | 12:17 PM
Nevermind there you go.
File Type: pdf
Old Oct 26, 2025 | 07:30 PM
thtguy's Avatar
2017 GLS 550
Whatever happened with this? Did you have to replace the starter?
