Intermittent Low Oil message
Yesterday, I took a trip to Yellowstone which is about five hours of driving all around, some hills for a few miles but nothing crazy. About 10 miles from home, I get a low oil message and pull over to see indeed, oil is at the low/min level. No suitable oil at the service station so I just drive the rest of the way home.
Then I spent the evening watching PCV videos thinking that's probably what's going on (and I'm not sure what the part name analogue is for the M278). Then this morning I take the dipstick reading and it is totally full.
Is oil getting trapped somewhere? I'm thinking the best place to start is by uplugging that oil solenoid valve that can get stuck(the one that made Tasos cuss a bunch in his video on it).
I'm thinking to take the initiative on those two parts but any other ideas would be welcome. (P.S. this is like my eighth Benz and I've never had to worry so much about engine critical shenangans like this, absolutely ridiculous, which you know
What in sam hill am I missing here.
From the owners manual:
Depending on the driving style, the vehicle
consumes up to 0.9 US qts (0.8 l) of oil over
a distance of 600 miles (1000 km). The oil
consumption may be higher than this when
the vehicle is new or if you frequently drive at
high engine speeds.
Depending on the engine, the oil dipstick may
be in a different location.
When checking the oil level:
Rpark the vehicle on a level surface.
Rthe engine should be switched off for
approximately five minutes if the engine is
at normal operating temperature.
Rif the engine is not at normal operating
temperature, e.g. if the engine was only
started briefly: wait about 30 minutes
before carrying out the measurement
Between your post at user 39039's excellent video here I think I got my answer https://mbworld.org/forums/general-m...ate-video.html
I knew ATF had temp requirements for measurement, but this is the first engine I've had that required it for oil temperature.
Did you pour oil in according to the manual's stated capacity or just until the dipstick was satisfied?
What I'm getting at is: Is there sludge building up in your engine reducing the capacity of useable oil in your engine?
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
2014 GL450, M278 engine. I put in 8.5 quarts because I wasn't sure if I got all the oil out of the pan, and then after running it with the new filter and getting that message for the first time, I put in another quarter thinking I didn't account for the filter housing area.
The low dipstick reading was after a 70 mile drive, which included going over the Teton Pass. From what I now gather this is not uncommon on longer drives.
