Disconnecting oil pump solenoid on M287
Old Jan 3, 2025 | 11:39 AM
gladerider's Avatar
GL450
Anyone done this? Any good step by step documentation?
Think I've read enough and may try it but cannot find a good step by step instruction on M287.
Old Jan 3, 2025 | 05:13 PM
jcarsnz's Avatar
Assume you mean M278,
No specific instructions I'm aware of, but best to tackle from the bottom, unplug the connector from the solenoid and zip tie the connector somewhere (I used the WP hose on my M157).
Here is a photo of the solenoid if you're not sure what to look for or where it's located (directly opposite the crank pulley, on the alternator side)
https://mbworld.org/forums/w212-amg/...ml#post8878913
Old Jan 6, 2025 | 02:10 PM
gladerider's Avatar
GL450
jcarsnz
ha. yes. i meant M278. i don't know how to fix the thread title.
wow. that thread is 99 pages long. not sure if i will have time to read that today. if you did it, how did you deal with the CEL after puling the plug?
thanks.
Old Jan 6, 2025 | 02:15 PM
W205C43PFL's Avatar
Originally Posted by gladerider
jcarsnz
thanks.
Survey on the OP of the thread: https://forms.office.com/Pages/Analy...g1Mkw1WkJVNS4u
Shows 27 of whom contributed to the survey unplugged had an M278.
By the way you could search keyword "M278" https://www.google.ca/search?q=https...te:mbworld.org
Old Jan 6, 2025 | 02:19 PM
W205C43PFL's Avatar
Or you could search within the site itself: https://mbworld.org/forums/search.ph...hreadid=877669
Old Jan 6, 2025 | 02:29 PM
jcarsnz's Avatar
jcarsnz
thanks.
No CEL on the ML63 after disconnecting, just a silent fault code. I think your GL will be the same, no CEL.
