GL-350 Coolant Leak - recommended materials?
I'm considering two options - There is a product called stop leak that I can inject on the high side when I charge up the AC. And there is a UV Dye product (same company?) that I can use.
Are these safe to use on the GL? Anything I should be worried about? I assume it's less than a 1 ton unit so I can use the "small" stop leak if I go that route.
Autozone also sells a recharge "kit" that has a leak stop component in it - not sure if those are any better/worse?
Hopefully someone knows the "best" route to go - should I try to find the leak and then somehow seal it , or put in a leak stop and hope for the best - or something else entirely (I always look for an excuse to break out the mig welder ;-) )
