COMMAND Head Unit Replacement Options
Old Aug 12, 2025 | 07:23 PM
frogger42's Avatar
gl450
The command unit went out on my 2015 GL550. My part number is A 166 900 52 15. I can't for the life of me find a match on ebay. what are my options for repair/replacement? At this point I don't mind considering after market, just don't know what to do.
Old Aug 14, 2025 | 09:45 AM
cadetdrivr's Avatar
2014 GL350 / 2026 BMW iX iDrive60
FWIW, if you go with a replacement (or used) OEM Comand unit, the vehicle will require programming for its anti-theft protections.
Surfing the internet, I have come across full Comand replacements from China (example, so they are out there) but I have no idea how well they work. Just looking at the specs, one would want to make sure to order one with the optional fiber optic connections.
Old Nov 21, 2025 | 02:27 PM
Benzenator's Avatar
C350-2013, GL350 BlueTec-2015, GLK 350 -2015
Great Option
https://roadtop.com/
Select_> Touchscreen and pick your model
Have installed on GL and GLK
Running smoothly now for 2 weeks.
Old Nov 21, 2025 | 06:47 PM
cadetdrivr's Avatar
This unit would be an upgrade that still requires a working Comand unit, no?
Old Nov 24, 2025 | 03:41 PM
Benzenator's Avatar
Valid point. Yes, this is for screen replacement only.
Check with a junkyard they can sell you one out of a wrecked vehicle.
Not sure if you will need a reflash due to VIN. So that's something you need to figure out.
Old Nov 25, 2025 | 01:30 AM
boosted305's Avatar
broom
Just went throug this myself... and yes a used one will need to be coded at the dealer, for which you will need the VIN of the car it came from.
Total cost would be approximately $1,300: Around $300 for the used heat unit, and I was quoted $1k for the coding and installation...
But instead, I found a place here in South Florida that repairs your unit for $880 with a 6 month warranty...one day turnaround.
I just picked mine up today, and it works perfectly...he had a stack of them in his shop and said its a very common failure.
Old Nov 25, 2025 | 09:58 AM
Benzenator's Avatar
Name?
Name of shop?
Old Nov 26, 2025 | 02:16 AM
boosted305's Avatar
broom
Name of shop?
M&B Specialist in Pompano, FL
