Suspension one inch lower on passenger side in all settings
I am having a weird issue with my GL550. I have changed the suspension valve block, the suspension compressor and the rear shock as I had a warning and the rear passenger shock failed. The car drives much better now but after each time I recalibrate the car to level, after driving the measurements are out by one inch. If I set the front suspension to equal on both sides and the back to exact and then drive the car, when I remeasure the front is one inch higher. I have reset this multiple times and in the beginning the passenger was one inch lower, now the drivers side is one inch higher. Can anyone point me in the right direction? I am recalibrating with a TOPDON Scan Pro.
THANK YOU in advance
Not sure how the TOPDON Scan Pro works but perhaps check if that is possibly the case.
Other item to mention, is while driving it's constantly adjusting, once you park, at least I've noticed that only after closing the door and locking the vehicle, it will adjust again.
BTW - @OldManAndHisCar - that was funny.
This is how you can manually set the stock ride height. Cars usually lower it right down, SUVs like to raise it a little.
