Gear issue 2015 GL450 and stranded in South NJ
Old Dec 13, 2025 | 03:39 PM
mofman's Avatar
Starts up no issue but when I attempt to go into any gear I hear an electronic noise from under car. I’ve disconnected the battery for 15 min and same issue. I have a xtool scanner and cannot see any glaring issues and no fault codes in transmission area.
Old Dec 15, 2025 | 07:37 AM
Jpkcpa's Avatar
2013 GL350
Both times I have encountered this (2013 GL 350) the culprit was the battery. I don’t recall hearing any noises from
underneath. Each time it would do it intermittently over several months. Change battery and good for a few more years (usually 3-4).
Old Dec 15, 2025 | 08:12 AM
mofman's Avatar
main battery or aux?
Old Dec 15, 2025 | 08:21 AM
mofman's Avatar
ran a complete diagnostic and no battery code popped up and battery was showing 14.7?
Old Dec 15, 2025 | 09:41 AM
Jpkcpa's Avatar
2013 GL350
1st time I changed both batteries. Second time I only changed main battery but I just remembered that the second time I also had a bad starter but it wasn’t changing gears intermittently before the starter gave out. Starting and restarting a few times would eventually allow the car to change gears (I assume ecu was rebooting or resetting something?). Sometimes on the first restart, others as much as 4 or 5 restarts.
