Air Supension Nightmare
Old May 24, 2026 | 12:24 AM
Jguz's Avatar
GL450
I’ve always had the c15561C code because of what i think was a bad valve block but i never thought to change it because the car was fine and drove smoothly and it stayed that way for a year or so.One day i notice that my gl450 was sitting real low on the front end of the car so i go and check it out and i see that the battery had died so i replace the battery and hear a leak coming from my driver side front air bag. after replacing that air bag i ran a level calibration and it was fine all systems were good. i drove it maybe some 15 mi and everything was fine until i went to go drive it back. Once i started driving the car was to the floor and riding was awful bumps all the way home. So i get home and i try running diagnostics and now IM thinking that my OG code has officially caught up to me and now my issue is after replacing the valve block i’m getting a c156c00 code and the vehicle does not raise at all but ride better than before but not perfect looking for any inputs
Old Yesterday | 10:10 AM
acetaylor's Avatar
07 C280 4matic, 2014 GL450, 91 VW Vanagon
I'll give you my 2 cents worth from my experiences. My WAG is that you compressor is bad. Everytime I had an issue regadless of symptoms and codes, it all turned out to be the compressor. It is not hard to replace, they are not expensive. Choose one off of Amazon (forget OE, yeah I know, it's the Holy Grail) put it in. Nothing ventured, nothing gained.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
