GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
DIY AMG x/w166 Brake pad replacement
Old Jun 16, 2023 | 09:45 AM
latinskllz's Avatar
'21 GLE53, ‘11 E63, '13 M3
Originally Posted by joecparrish
After you removed the old pads, did you use a pad spreader to push the piston in? The piston should go flush with the caliper body.
Other than putting the electronic parking brake into service mode, there is no other “trick” to servicing the brakes on these vehicles. It’s just the standard process.
—Joe
Yep. Didn’t do that. Feel like such a noob replying without researching enough.
thanks for taking the time to reply.
Old Jun 16, 2023 | 11:35 AM
joecparrish's Avatar
2017 GLS63
No worries. This thread walks you through the complete process:
https://mbworld.org/forums/gl63-amg-...ml#post8238304
–Joe
