The friction power of the torque converter lockup clutch is too high
Im also facing the same problem symptoms with my 2007 CLS550 with the same 722.9 gearbox I assume. Pulled codes P2783 (torque converter temp too high) and P0741 (torque converter clutch solenoid performance or stuck off).
I recently bought the car, and the dealer have now agreed to replace the TC with a new Sachs converter which seems to be only 25% the price of a original Mercedes TC. Crossing my fingers that this fixes the issue.
Please keep us posted... happening on my 2012 s550 120k miles.
Later on he decided to replace the complete automatic gearbox. He installed a used one from another car with similar mileage. The only thing reused was the computer board since the car will not accept a different serial number. The "new" gearbox created a lot of problems for the workshop and it still does some strange things now and then, like jumping out of gear. Totally by car spend 12 weeks at the workshop get this fixed... The original problem is however gone after replacing the gearbox and I don't see fault codes P2783 or P0741 anymore.
The torque converter has a lockup clutch that is engaged in steady state conditions (like driving down the highway) to bypass the torque converter and improve efficiency. It is actuated by hydraulic fluid that is controlled with a solenoid. When the solenoid is stuck off, the lockup clutch can’t engage when the transmission control unit commands it to. This will result in excessive heat in the torque converter since all the slip heats up the fluid. These two codes seem to point to a faulty TCC solenoid, likely due to a mechanical failure or blockage due to debris since electrical failures likely have separate diagnostics and would yield a different DTC. I’m not sure if that solenoid can be replaced separately or if the whole valve body needs to be replaced as a unit but that is where I would start to look. If after disassembly and inspection the solenoid appears to be fine, it might be a blockage in one of the hydraulic passages in the valve body’s TCC circuit.
im the car drove fine for 2 days then the revs got stuck at 5000r when i pulled over the car would not select reverse or drive turned the ignition of and every thing was ok but i get a distinkt clunk when i select drive was told i need a new valve body replacement but i have gearbox speed sensor faults and friction power of the torque lock up is to high 2783 i think
dont know if its the torque converter or the conducter plate ???
can anyone help
