TOTAL SYSTEM SUSPENSION UPGRADE 2020
Have attached instruction sheet P/N 504016-3 J $380
This Camber and Caster kit simply replace the front upper arm inner bushings providing precise adjustment.
Up to 1.5 degrees Positive or Negative. Bush extraction tool supplied and can be fitted without arm removal.
Plus instruction sheet for P/N 504016-1 M $595
This kit also provides precise Camber and Caster adjustment up to 2 degrees and at same time replaces the 4 front highest wearing suspension bushings (especially the 2 rear OEM which are expensive to replace). Also supplied with bush extraction tool.
Also REAR instruction P/N 504026 K $480
Camber and Toe doubling the existing adjustment range.
Replaces the 4 lower arm (highest wearing) rear bushings.
Precise single wrench adjustable. Bush extraction tool supplied.
Just click below for instruction sheet:
https://imgur.com/pLX3seG
https://imgur.com/tcjk0N1
https://imgur.com/DOjaYhc
Kevin
