GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
AMG GLS63 Ride Height Dimension Help
Old Aug 16, 2020 | 10:06 AM
carlosamg50's Avatar
AMG GLS63
Hi All
Im trying to establish various factors that could be causing vibration at highway speed (other than the obvious wheel and tyre balance) and I spent time driving in Comfort setting today and started to think it just felt more settled overall so measured the height of each corner on my driveway when i got home, and in each setting C, S, S+ and raised.
I found that the rear doesnt seem to react to the commands from the console switch quite as well as the fronts, I can stand and watch the fronts drop when S+ is raised, not as obvious in the rear, one corner in particular didnt really do anything between the settings but did raise up when i raised the suspension.
Anyone with an AMG able to measure there one to tell me what dimensions they got across the different modes please? I took it from the top of my 22” rim (rim not tyre) to the bottom if the wheel arch in the centre of each arch
Maybe i need a recalibration?
Carl
Old Nov 27, 2020 | 08:31 AM
AMG GLS63
Hi can anyone with a GLS63 X166 on 22" factory wheels and tyres help with this please, dealer says its not possible to use measurements to check the height of the car, it has to be done with their equipment, I just think mine sits high at the back end so wanted to take some dimensions from floor to wheel arch or if not using 22" wheels then wheel centre to wheel arch to gauge if it is or not.
Thanks in advance of anyone helping
Carl
