GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
Airmatic Malfunction.
Old Sep 25, 2020 | 06:10 PM
Chris Jensen's Avatar
2015 GL63 AMG
2015 GL63
The truck is all the way Down. Obviously drives bouncy and stiff. after about ten minutes the truck profile with the up arrow is displayed with "malfunction" underneath. The truck did not raise and will not raise.
I suspected a failed compressor; checked 40 amp fuse, it was blown. Bench tested relay good. disconnected the power from the compressor, replaced the fuse and checked for 12 v. nothing.
started the truck pressed the raise button and checked for voltage again.... Nothing at the plug(wire coming from relay and fuse) WHY!
I have a new compressor ready to go in but I'm not so sure its the Compressor now that i can't get power to the thing.
Is there any other fuse or relay in this circuit?
Please HELP.
Old Sep 26, 2020 | 12:38 PM
2015 GL63 AMG
Compressor bad... changing now.
