Front Lower Ball Joint Nut Size needed!
Thanks in Advance.
UPDATE: So it turns out to be a 46mm 12 point.
Do you also know the size of the upper nut, where the Joit Ball is mounted at the lower control arm? I have a 28mm max which is too small, I measured an outer diameter of 40mm, so my guess is 36mm nut but could be wrong. Thanks for your advise.
