Coolant seepage (leak) out of top driver side Rad??? Please help
motor”. Root cause?
Which JB weld product did you use?
How did it hold?
i will add that i also used it on the upper rad hose which separately developed a pinhole leak but I do not recommend this for long term, I only did this for a short term fix (so far it’s been over a year) because the dealer priced the hose upper rad hose at $267.00
I sourced a Chinese now available upper rad hose for $29 from eBay and have yet to install it,
for now I have placed the new hose in the trunk under hatch area but do plan to replace it.
Bottom line I don’t mind the JB weld fix for the rad “pocket” shown in photos where it leaks from but I honestly think we should all be cautious on using JB weld on the rad hose (plastic parts crack and leak pinhole matter coolant). I mean, the last thing is you don’t want a hose to completely fail,
