GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
Operating Fluids question
Old Jan 29, 2025 | 06:06 PM
resoplez's Avatar
2017 GLS 63 AMG
Hey guys, planning a complete Fluid change on my 2017 GLS63 AMG.
I'm looking for the operating fluids datasheet https://operatingfluids.mercedes-benz.com but I found it really confusing.
Can any of you point me on the right direction for the MB-Approval for the following items?
-Transmission
-Transfer case
-Rear Differential
-Front Differential
Or what do you use?
Thanks in advance
David
Old Jan 29, 2025 | 08:00 PM
W205C43PFL's Avatar
-Transmission
-Transfer case
-Rear Differential
-Front Differential
Or what do you use?
Thanks in advance
David
Yes it is confusing but first you need to know the specifications and certification listed for your model in the operator's manual then you look up the fluids.
Old Jan 30, 2025 | 09:40 AM
nero550's Avatar
2010 gl550 , 2017 gl 63 amg
-Transmission
-Transfer case
-Rear Differential
-Front Differential
Or what do you use?
Thanks in advance
David
If you're doing this yourself it's best to get the fluids from the dealership, I recently did all of these changes and can go check containers for specs , but there was a run around at different dealerships recommending different oils, you just need a knowledgeable salesperson.
Old Jan 30, 2025 | 10:43 AM
resoplez's Avatar
2017 GLS 63 AMG
Thanks for the answers guys.
I will go and check the owners manual. My thought was, what is written on the user's manual could be outdated, reason why I went to https://operatingfluids.mercedes-benz.com
Can you tell what fluids you use?
Old Mar 26, 2025 | 05:02 PM
resoplez's Avatar
2017 GLS 63 AMG
Owners manual has no information related to differentials and transfer case fluids.
Old Apr 11, 2025 | 10:39 AM
W205C43PFL's Avatar
Sorry for the late reply. I just noticed your post, if the specifications are not available in the manual, you should get a copy of WIS to help you out. I believe that the transfer case shares the 722.905 transmission fluid, so when you do transmission, both gets drained. I would appreciate someone confirming for me just in case, and correct me if I am wrong as I don't want you to mess things up.
