GLA Class (H247) Produced 2021 to Present
Quick Access on GLA 250
Old Oct 14, 2021 | 11:42 PM
N514864's Avatar
2024 E350 4MATIC SEDAN. 2021 AMG GLA35
My wife's AMG 35 is supposed to have Quick Access and then Car Wash Mode. It says in the GLA Manual that I should be able to get to Car Wash by going to MBUX Home, then to Settings, and then to Quick Access. On your models, do you all have these options per the Manual? I'm wondering if it's somehow limited to which options/packages you have. I have tried linking up with a Coder who says that no Quick Access is a Dealer/Manufacturer issue but that they could code Car Wash Mode if I had Quick Access. Thanks for any insight you can give on the GLA 250 model MBUX.
Old Oct 15, 2021 | 09:18 AM
mmilo's Avatar
2021 GLA250
I have a GLA250, not AMG, and I saw the same thing in the manual. I couldn't find it on any menu in my car. The dealer said my car wasn't equipped with it. I wish the manual would specify which models and packages have each feature; it's confusing enough when you try to buy the car you want, the least they could do is to make the manual accurate.
Old Oct 16, 2021 | 03:40 PM
190Efan's Avatar
1991 190E 2.3
Sounds like your best bet might be to contact your local MB dealer and see if they have any additional suggestions on how to find the car wash mode for your particular MB.
Old Feb 19, 2022 | 12:35 AM
david_sd's Avatar
2021 GLA 250
Same here.
Old Feb 19, 2022 | 03:09 AM
Eaton's Avatar
Top Answer: 1
It's unclear what the prerequisites for this feature are, but RJ can activate it for you.
